M6 running hot?
Old Feb 14, 2005 | 07:22 PM
JimMueller's Avatar
Default M6 running hot?
My center console was emitting a lot of heat this evening while driving. The Pro 5.0 stick was more than warm to the touch, and the plastic near the front edge of the seats was very warm.
It seems like the shifting is not quite as smooth as usual. It appears that the last place I took to have a clutch installed (~3 weeks ago) may have further damaged the two black seals under the leather boot.
Suggestions?
Old Feb 15, 2005 | 09:11 AM
1madss's Avatar
Make sure your fluid level is correct. While disassembling mine for the rebuild it only had about a quart of fluid in it. I'm sure that contributed to the bearing damage.
Old Feb 15, 2005 | 04:46 PM
JimMueller's Avatar
I bought some Syncromax, plan to flush it tomorrow. The only way the fluid would disappear is if I had a leak, correct? I mean, it wouldn't boil due to abuse.
