Richmond 6 + LS1?
Old Feb 2, 2005 | 02:59 PM
2001CamaroGuy's Avatar
Default Richmond 6 + LS1?
would like to have a closer ratio tranny with 5th being 1:1 and 6th at a 0.7:1......is there a bellhousing to put a Richmond 6 behind an LS1?
Old Feb 2, 2005 | 08:08 PM
WickEdSix98's Avatar
McLeod makes a bellhousing for it I think.
Old Feb 12, 2005 | 08:16 AM
02SOMWS6's Avatar
I have a richmond 6 speed in my 3rd gen F-body. I run 3.89 gears and it acts like it has 4.88's 1st- 4th and 5th still pulls, I had to use 5th at the track when I ran out of gear using NOS. I also had to send it back to richmond 3 times with problems, they fixed it for free but that was a lot of wrenching to in and out that tranny. My car in the sig has the T56. At 1,200 miles I had to have it apart to replace the stock slider key's with a set of billet slider keys, I also changed the shift fork and some other little things. I like the T56 better because it's not a top loader tranny and shifts nicer and you can shift it faster. The richmond has the old style bars on the outside of the tranny like the old munci's and borg warnner tranny's and takes a little more to shift and in my opion the richmond is the weaker of the 2.
Old Feb 12, 2005 | 08:55 AM
calhoon's Avatar
Uh do you know what a top loader is? A T56 is NOT a top loader.
Old Feb 12, 2005 | 10:24 AM
02SOMWS6's Avatar
No ****- the richmond is a top loader you assss
Old Feb 12, 2005 | 10:09 PM
Tudds's Avatar
hahahhha
Old Feb 15, 2005 | 05:55 PM
jmd's Avatar
jmd
Arrow
You might want to watch your P's and Q's before flaming certain people. The Richmond is not a top loader either. The case separates along the centre; nothing about it is a top loader.
Old Feb 15, 2005 | 05:56 PM
02SOMWS6's Avatar
My bad, the T56 is the top loader , the richmond is not a top loader. The richmond has bars like a old munci. The richmond is the weaker tranny of the 2. I have both tranny's, just typing quicker than I'm thinking
Old Feb 15, 2005 | 06:01 PM
jmd's Avatar
jmd
Arrow
Lakewood makes a standard GM pattern bellhousing that allows the Richmond to be used behind a Gen III
No, the T56 is the internail rail shifted transmission. It's not a top loader. A true top loader (as in olde Fords) still uses levers on the outside of the trans. as does the Richmond.
Just stop posting.
