Need Help Asap!!
Old Feb 14, 2005 | 10:05 PM
ls1ow's Avatar
Default Need Help Asap!!
ok im going back to a m6 from th400, and i bought a new ram power grip cluch and new 02+ slave, and im reusing the stock 00 master, ok well we got it all together tonight, and nothing i cant get into gear???? is this the master do i need to buy a ram adj, one ive been down the road before with the car doing the same thing all to find out i had broken the springs on my spec 3, i want to be 100% postive its the master cause last time i spent $300 on master and slave that i really didnt need, oh and this might help with the car off i put it first held the clutch turned it on, no wheel movement, then a let out on the clutch and it ingauges and the wheels start to turn, then i tried to give it gas and the wheels dont speed up in fact that car never goes past 1500 with it FLOORED????? whats going on here????
thanks for the help in advance.
John.
Old Feb 14, 2005 | 10:42 PM
99CamaroSS's Avatar
sorry i dont have any info for ya but i figured i'd help ya keep it at the top of the list...i'm also planning on getting a powergrip hd this season so let us know if it turns out to be a problem w/ the clutch instead of the master...also i woulda deff. done the adj. master, rams tech told me rams clutches are designed to have it...and thats what i've heard from good feedback w/ people that have done this...good luck w/ getting an answer and solving the prob.
Old Feb 15, 2005 | 08:24 AM
P Mack's Avatar
Ok, with the rear axle in the air you say the wheels start turning when you engage the clutch, but do they stop turning when you push it back in? I bet it's the clutch, not the master cylinder just cause my ram clutch did the same thing, engaged right on the floor. The reason you can't get past 1500 rpm could have to do with traction control cause your rear wheels are spinning and the front ones aren't, so try turning it off.
Old Feb 15, 2005 | 07:45 PM
ls1ow's Avatar
ok the traction control makes sense, so what did you do to fix the cluch issue p mack i mean what was causing it???????????
Old Feb 15, 2005 | 08:22 PM
P Mack's Avatar
I just put the stock clutch back in for now. When I eventually have enough power to need the ramit i'm gonna probably use a shim from spec to get the slave closer to the clutch. Maybe the .040" one but i'm not sure.
Old Feb 15, 2005 | 09:01 PM
ls1ow's Avatar
hrmm well tonight we spent a long time trying to bleed the clutch, i think i like 9 times, and it still dosnt build any pressure??????? is it just not enough bleeding or what????damn this thing is making me really mad
Old Feb 15, 2005 | 09:14 PM
jmd's Avatar
jmd
Arrow
Do a search for jmd method to bleed it. Check your master up top (pull back the rubber boot) for leaks too.
Old Feb 15, 2005 | 10:01 PM
ls1ow's Avatar
did a search but didnt come up with anything can you pm me and explantion of your method please
thanks,
John.
Old Feb 16, 2005 | 07:45 PM
ls1ow's Avatar
well day 3 of trying to fix this thing has just gone by and now with the ram master in it, it wont build pressure, my guess is the ram is defective so im going to try another tom??? anyone else have any guess????
By Brett Foote | 2026-06-04 05:00:17
