OK wtf
Old Feb 15, 2005 | 04:07 PM
badaSS346's Avatar
Default OK wtf
I have been trying all day to get this damn factory hurst shift *** off the car and the f^cking thing will not move. It seems like the actual shifter is gonna give before the ***. Is the a secret to getting this thing off? Im I doing something wrong?
Old Feb 15, 2005 | 04:12 PM
Tranzor's Avatar
They are stuck on there good from the factory... I had a hell of time getting my stock one off there. Just give it one good jerking twist to try to break it loose.
Old Feb 15, 2005 | 04:39 PM
badaSS346's Avatar
I cannot believe this ******* thing will not come off. I have no idea wtf the problem is i have been tryin for 2 hours and nothing. What i find hard to beleive is that someone as stong as i am cannot get it off then no one can!
Old Feb 15, 2005 | 07:10 PM
TripleBlackRamAirT/A's Avatar
lefty loosey righty tighty. It just spins off, i dont know what else to tell ya.
Old Feb 15, 2005 | 07:14 PM
WS-Sick's Avatar
Did you get it off yet?
Old Feb 15, 2005 | 10:37 PM
badaSS346's Avatar
NO! i gave up...i'll eat my wheaty's and try tomorrow.
Old Feb 15, 2005 | 10:54 PM
01350ss's Avatar
try to get a belt around it and tug on the belt. try to get some leverage.
Old Feb 15, 2005 | 11:25 PM
Turo's Avatar
maybe the previous owner superglued it or jb-welded it there. no joke, i have seen people do that quite a bit.
Old Feb 15, 2005 | 11:42 PM
BuBbABFP's Avatar
how do u get the black rounded leathered one off, it just spins freely..
Old Feb 16, 2005 | 02:53 AM
LSWannabe's Avatar
If giving it the two handed strangler mangler grip and turning that bitch to the left wont work. I suggest a tericloth towel and a giant monkey wrench!
Old Feb 16, 2005 | 08:27 AM
calhoon's Avatar
If you are just changing the shifter, you can remove the handle/ stick at the shifter as an assembly. Swap the shifter out and re-install the stick/**** assembly. If you are swapping handles and re-using the ****, it may be easier to separate the **** from the stick with it off the car( vise & strap wrench work well and dont marr the ****).
Old Feb 16, 2005 | 10:29 AM
badaSS346's Avatar
Yeah...i gonna give that a shot after i get home from work. I felt like i was actually twisting the shifter...has anyone ever herd of doing damage to the tranny like this?
Old Feb 16, 2005 | 01:10 PM
Joker's Avatar
I had a bitch getting mine off too, I grabbed on and twisted that thing hard to the left and after about five tries, it finally broke loose. Try a thick cloth and set of vise grips for leverage. Good luck!
Old Feb 16, 2005 | 01:23 PM
Dustin Butts's Avatar
Yeah a big pair channel lock pliers works well too.
Old Feb 17, 2005 | 07:49 AM
calhoon's Avatar
Another thought to consider using my disassembly suggestion. If you reef on the ball without supporting the stick handle base, you could break the rubber isolation bond. This is not a problem if you are not going to reuse the stick. It could also damage the shifter internals- again not a problem if you are replacing the part.You will then have to take the broken stick to a vise and disassemble it if you want the ****. I would just do that to start, as suggested above.
