how to change a slave cylender
Click on the install documents icon, then look for clutch install. It'll show you step by step how to do it. Just follow up to where they drop the tranny, so you can unbolt the slave, then put it back together.
Not that hard really...just kind of a pain to be working on your back. I would add that some type of trans jack is a MUST. The transmission is a LOT heavier that I thought is was....it's probably close to 250 lbs.
haaahahaaaaa....It sure feels that heavy when you're by yourself. It actually weighs about 135 I think.
https://ls1tech.com/forums/showthrea...ick+disconnect
