Spec????? help
Old Feb 24, 2005 | 12:49 PM
pontiac's Avatar
Default Spec????? help
Ok I have 40,000 miles on a Spec 3 x pad, car is not slipping but mackes a skeeck when takeing off and its cold. (blow my tranny up) so now is the time to replace the clutch if i need to should I or not and if so do I go with a Spec 3 or a 3+.......I have an aluminum spec flywheel do I have to rebalance the flywheel and presure plate together or not?
