Confusing problem with my M6
Old Feb 27, 2005 | 03:38 PM
SLP CARS '98's Avatar
Default Confusing problem with my M6
When I have my clutch pedal pushed down to the floor and the car is in gear the car still moves as if the clutch is partially engaged. I put the clutch in approx. 2,000 miles ago and when I first installed the cluch and would rev the motor with the clutch pedal completely down to the floor the car would accelerate a little. It seems as if the problem is only getting worse. I have a spec stage 3, fidanza alluminum flywheel, and updated gm hydraulics. I don't have any idea where to begin with this problem. It is also hard to get it into gear. I'm guessing maybe because the clutch is not fully engaging. Any advice would be greatly appreciated. Also the shim was installed at time of clutch installation.
Old Feb 28, 2005 | 12:57 AM
991LE's Avatar
The most likely culprit is air. Getting all the air out can be a pain in the ***.
Old Feb 28, 2005 | 01:02 AM
P Mack's Avatar
Air or the shim is too thick.
Edit: I meant thin, not thick. Apparently I'm retarded
Old Mar 9, 2005 | 12:04 AM
So if the shim is to thick I assume that means I should take it out?
Old Mar 9, 2005 | 10:53 PM
Ok well I've bled the system down and I know there is no air in it at all. The problem still persists. Is it possible I may need to upgrade to the Mcleod master cylinder? I already have the updated 01-02 master cylinder. I don't want to start throwing parts at it but I'm not sure what the next step is to take. Any and all advice is greatly appreciated.
Old Mar 9, 2005 | 11:01 PM
scifone's Avatar
mine was doing the same thing a few weeks ago. bleeding cured the problem for me.
Old Mar 9, 2005 | 11:12 PM
Unfortunatly bleeding the system hasn't fixed my problem. The only 2 things I can think left that may be wrong is the master cylinder or maybe I need to add another shim. Like I said I don't want to start throwing parts at it but I'm afraid that's what it might come down to. Also the clutch, flywheel, and updated hydraulics have about 2,000 miles on it. People on other forums with the same problem have replaced there master cylinder with a Mcleoud and the problem has gone away. Do you think if I do this I'll get lucky and the problem with be cured?
Old Mar 10, 2005 | 12:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I had the same problem, and then switched to the mcleod adj. master. I was able to adjust it to compensate for the "Still engaging when reving with clutch pedal on the floor." issue.
Check Ebay. I got mine new for 90 shipped.
Old Mar 10, 2005 | 01:14 PM
jerflash's Avatar
hey do you have the old flexable green shim?
i did and had some problems getting into 3rd sometimes
they ahve a new metal thicker shim they use now
i called them about it and they sent me the new shim for free
did not cost me a thing not even shipin
Old Mar 18, 2005 | 10:24 PM
For those who have the same problem that I've had I have some news about what has happened recently. I talked with several people from sponsors and from spec. 9 out of the 10 people I talked to said to change out the master cylinder with the mcleod. I swaped it a few days ago with a new mcleod adjustable master cylinder and bled the system down. I drove the car home 45 miles and still had the problem. Obviously I was not happy till tonight when I had to move the car. The clutch disengaged perfectly normal. I don't know what happened all of a sudden but I'm happy to know my clutch disengages perfect now.
