Difference Between Stock Hurst and aftermarket?
Old Mar 6, 2005 | 07:23 PM
Trent's Avatar
Default Difference Between Stock Hurst and aftermarket?
Is there a difference? I've got a possibly really good deal on a Hurst shifter with a Lou's Short stick on it. It's the factory Hurst and mine didn't have even that. Is there a difference between that and the aftermarket Hurst? I searched and couldn't seem to find what I was looking for. Sorry.
Old Mar 6, 2005 | 08:17 PM
jerflash's Avatar
the difference is that the aftermarket hurst has a better feel...more solid but not much over the stock hurst with the LSS. The aftermarket has a slightly shorter throw. The stock is more springy then the aftermarket hurst but the aftermarket one has the stops which stops you from over shiftin...a problem i have.
all in all if the stock had stops i would use it but i use the aftermarket because i dont need to messup my rebuilt tranny
