grinding from 1st to 2nd at high rpm shift
when i shift from first to second gear slowly at high rpm it goes in ok but when i try to shift fast between first and second it grinds and won't go in. does anyone know what would cause this? thanks.
I had that exact problem. If you shift from 1st to 2nd nice and slow it goes in, but if you put it in fast it grinds then goes in. If I remember correctly my 2nd gear syncro went out. So I had tranny rebuilt stronger.
Depending if you do it yourself. You can get a whole synchro rebuild kit for around $200 and do it all yourself but I, personally, would not consider it an "easy install". A shop would prob charge you a standard charge just to take out the tranny and also to tear it down and replace the synchro(s). So it could cost you from $200 - $700. Synchros are my absolute nemesis I can share in your pain. It's sad these cars punish us for not granny shifting.
