Only my knuckles are bleeding.....
So I just ordered a MityVac 4050 Silverline Plus from Amazon.com. Should be here on Friday. Maybe I can learn how it works in short time, put a vaccum on the resevoir and be done with it!!
Wish me luck.............................................
free air getting in when I remove the pump (I had tiny bubbles coming out when I unplugged the mityvac)
I have RAM adjustbible clutch though (not Mcleod)... it is stack with adjustible tip on the pedal rod.
my clutch feels fine now, I did not have to bleed the clutch through the bleeder valve (but I was just changing the clutch master cyl on my '98, not the slave or the clutch itself)
I just got word from Amazon.com that the estimated delivery date was moved to March 15th
. Oh well there is nothing I can do untill it gets here
. i guess i need to put the adjuster in some? We will see...
