mityvac???
Old Mar 10, 2005 | 12:50 PM
pontiac's Avatar
Default mityvac???
got a mity vac... so I put the tip of the mityvac in the MC resevour.......then pump the mityvac.. THE whole time the bleeder on the slave is closed.??
So the fluid comes out with the air I am guessing.is so what happend to the peddal while this is happening??? will it help to push the clutch peddal in the use mityvac???
someone please explane in detale???
Old Mar 10, 2005 | 01:50 PM
5 Liter Eater's Avatar
Stick the mitivac needle into the hole where the master hose connects to the reservoir. Make sure it seats. Pull ~20" Hg on the mitivac. Get in and pump the pedal with some long strokes and short strokes until you stop seeing bubbles. Make sure the level of the reservior does not drop below the needle. When done, top off the reservoir with new fluid.
Old Mar 10, 2005 | 02:56 PM
RX-Ben's Avatar
check the link at the bottom of this thread:
https://ls1tech.com/forums/manual-transmission/283961-bleeding-nightmare.html
