How does an adjustable MC work?
Is this correct?
Thanks!
Ben
The best way to do it is to yank the tranny, measure the diatance from the back of the block or bellhousing to the pressure plate fingers, then measure the distance from the front of the tranny or bellhousing to the end of the throw out bearing that is compressed all the way. (all depends on if you remove the bellhousing which I'm not sure what the F-Body guys do). Then you can figure out how far the compressed slave is from the pressure plate fingers is. When you put the new clutch in, measure the distance from the fingers to the block/bellhousing again and shim the slave to make up for and change. Ideally, if I remember correctly, you want ~.125" distance between the compressed throw out/slave and the fingers of the pressure plate.
HTH
https://ls1tech.com/forums/showthrea...highlight=.125
Really good info IMO.
One question- you measure to the tip of the clutch fingers (where each comes to a point), correct?
Just bear with me and make sure that I'm understanding the measurements:
(My tranny will have the bellhousing on it)
1. Measure from the block to the tip of the clutch fingers. I'm thinking this is going to be tricky to be really exact. Any suggestions on a good technique?
2. Measure from the bellhousing (the surface the would mate to the engine) to the tip of the TOB with the spring removed. It should be relatively easy to get an exact measurement on this (straight edge on the bellhousing and measure down from there).
There should be a .125" difference in the two measurements (the TOB/compressed slave should be the shorter distance).
Sound right?
Thanks!
http://www.stockcarproducts.com/clutch8.htm
This will take the guess work out of clutch installs.
Ben
Sound right?
Thanks!
