Grinding going into third
Old Mar 22, 2005 | 07:55 PM
slowscott's Avatar
Angry Grinding going into third
Most of the time my transmission shifts perfectly smooth in every gear but, sometimes it grinds going into third. About half way through the throw it just hits a wall and makes a bad grinding sound. It only happens at low rpm and I have a pro 5.0. I was thinking it was the syncro but, I would like other opinions.
thanks
Old Mar 22, 2005 | 08:51 PM
thesource's Avatar
Its definately something with the 3-4 syncro assembly and or fork . Upgrade to the steel fork and replace syncros and 3-4 keys .............
Old Mar 22, 2005 | 09:00 PM
slowscott's Avatar
About how much would that cost?
Old Mar 22, 2005 | 09:12 PM
1FST99Z's Avatar
not sure on the cost. i know I had a local tranny shop do it and put the updated syncro's, blocker rings, and forks. o and also replaced third gear itself b/c I let it grind so much it wouldnt go into gear. that was a 300$ mistake. so if anything just try to stay out of it b/c the more you grind it the worse it will get. it totaled me about 1200 bux to get it rebuilt with all the latest and greatest parts and that includes the 300 bux for third gear. hope this helps
Wesley
Old Mar 22, 2005 | 09:15 PM
slowscott's Avatar
thanks, i hope i dont need to spend 1200 bucks! I guess i won't be using third for awhile.
Old Mar 22, 2005 | 09:18 PM
thesource's Avatar
Where are you located ?
Old Mar 23, 2005 | 01:47 PM
slowscott's Avatar
NJ, I already have someone in mind to do the work, just wanted to get an estimate on parts cost.
Old Mar 24, 2005 | 12:00 PM
fasteddyss's Avatar
I rebuilt my tranny for the same condition you have. I have to say though, that I did not find anything wrong inside. I am now convinced tha the main source of the occasional grinding into 3rd just needs the drill mod.
I would try the drill mod first. Your tranny may be fine!!!
Old Mar 24, 2005 | 01:48 PM
Evo98z's Avatar
TTT for the estimated parts cost
Old Mar 24, 2005 | 01:55 PM
ArcticZ28's Avatar
I had the 1-2 synchro go in mine... charged me about 750 to tear down and rebuild with the new synchro... last time I ever let someone else do the work on my car.
