reverse locked-out
Old Mar 24, 2005 | 11:21 AM
777's Avatar
777
Default reverse locked-out
my reverse lock out is stuck..or something to that affect...it will not go over to the reverse fork...what *could* cause this problem...
Old Mar 24, 2005 | 12:23 PM
Coy's Avatar
Coy
check the fuse. ENG SEN-20 amp
Old Mar 24, 2005 | 12:29 PM
777's Avatar
777
already did...it is fine...i have a question (prolly really dumb) are the numbers on the fuse box supposed to match the numbers on the fuses...cause i don't know if any of the fuse numbers match the numbers on the fuse box
Old Mar 24, 2005 | 02:51 PM
777's Avatar
777
anyone else...
Old Mar 24, 2005 | 03:30 PM
P Mack's Avatar
Is your reverse lockout solenoid plugged in to the wiring harness?
Old Mar 24, 2005 | 03:59 PM
777's Avatar
777
i don't know...car is not with me right now...i don't see why not...i just parked it and then hmm no reverse to back up...so i got a push haha...there are a lot more things wrong with the car as far as idle quality but i don't see what happened to my lock-out...could it come unplugged if you drug the bottom of the car on some grass for about 20ft... i was driving down a dirt road and the next thing i notice i was dragging the exhaust (dumped true duals) and who knows what else on the grass in the middle...
Old Mar 24, 2005 | 04:00 PM
777's Avatar
777
i guess that is what you get for a lowered car when you are used to stock ride height
