Textralia clutch is in...WOW!!!
I Just installed a textralia clutch in my car....all I have to say is WOW! this clutch is SMOOTH!. it had no chatter at all from the start. the engagement feels stock as does the pedal pressure. this clutch is a dream to drive on the street. like many others, I had just accepted the fact that a 700+ rwhp clutch was going to be an on-off switch. when Peter told me that this clutch would drive like a stock one I was VERY skeptical. well, I am now a believer in Textralia. it certainly has great street manners. the true test will be the drag strip in a couple of weeks, but I am confident that it will hold up well. if you are looking for a great driving street clutch that will handle big power...this is it.
Tom
Tom
I am getting sick of adjustable masters my new mcleod lasted about two weeks and think leaking air or something you have to pump it like two hundred times to be able to get in gear and then after letting car sit another week or same deal.Might try one time to rebuild this POS.
I was serious about maybe getting the clutch master as it using stock master
but dont' think the stage 3 clutchmaster is rated for like 700 hp or is it...? and doesn't it need new flywheel..was thinking of fidanza I think lighter and planning a turbo car.
This textralia might be ok..how much is it..does it use stock hydraulics or need adjustable master.what about flywheel.So pedal pressure is like stock and no chatter in traffic.Sounds good to me maybe.Do you have to order them from australia?
6600 rpm clutch dump of death Administrator
SR71 glad to hear your results.
The Textralia clutch uses all stock GM parts, and it comes with a new GM flywheel balanced to the clutch. So, no need or use for an adjustable master, etc... In fact I found mine worked better when the adjustable McLeod was removed. I have the adjustable sitting on the shelf and the car is better without it....
everyone keeps asking how much power.....well it was 663rwhp with his old setup, his new TT setup should be a little stouter with 2 61mm turbos, glad you like the clutch tom youll have to let me feel the petal pressure sometime if it works out good for you ill consider one when this spec 3 of mine with 300 passes on it takes a dump
Originally Posted by Dustin Butts
J-Rod,
Have you had a chance to beat on yours at the track yet? If so how did it do?
Originally Posted by J-Rod
Leaving at 6600 on ET Streets in the Z06 we were cutting some 1.4 60's. It may be time for some new tires as a couple of the passes the car spun hard. The clutch engages very well and had 0 issues.
Hey J-Rod you think that Aussie clutch would be suffice for my setup. I have left a thread in Manual Transmission. Please read it if you have time and drop a line as well.
https://ls1tech.com/forums/manual-transmission/297219-ppls-choice-clutch-kits.html
Sorry for the HIJACK!!
J
Originally Posted by Nine Ball
non-sponsor e-pimping threads have been removed.
ah.
THAT EXPLAINS WHY I CANT FIND ANY PRICES OR INFO ON THE DAMN CLUTCH.
THANKS.
PS: someone PM me the prices and someplace to buy it... id like to do a price compare, ect... find the cheapest place... you know, do the kind of thing this forum is here for...
thanks, MrDude_1
King of Pigskin Knowledge
Originally Posted by MrDude_1
thanks, but their website is useless.
no distributors listed.. only "coming soon"
no forums
no pricing
no nothing... except a email addy that when i click send on, doesnt do anything
where is everyone getting theirs from?
no forums
no pricing
