luk clutch kit?
Old Mar 26, 2005 | 11:19 AM
mattslightning's Avatar
Default luk clutch kit?
what do you guys think about thier clutches ? need to replace clutch in my 99 m6 and curious on which clutch to go with
Old Mar 26, 2005 | 04:56 PM
QuickBowtie's Avatar
That reall depends on what your mods are. If you are stock, the basic LUK should work fine (its equal to a z06 clutch). If you have a small/medium cam with boltons and plan on racing your car at the track, you will want to run a clutch that is stronger. I really don't think the LUK clutches are worth the money though. But that is just me.
Old Mar 28, 2005 | 09:56 AM
black99ta's Avatar
Luk makes the stock Z06 clutches and also the Pro Gold upgrade, both are quality units. I've got a stock Z06 ready to go in my M6 TA so I can let you know how it goes in a month or so.
You can look up the exact torque ratings, but a bolt on car probably only needs the regular Z06 and a car pushing 400 rwhp should have the Pro Gold. Search on Luk Pro Gold and you'll find contacts to order either one.
Old Mar 28, 2005 | 10:21 PM
wrencher's Avatar
wrencher
I have seen some McLeod sets have LUK pressure plate hats & diaphram springs.
Old Mar 29, 2005 | 05:22 PM
thanks for the info next month purchase then stupid me found a good deal on ebay for a set of those new mickey t drag radials and bought those instead of a clutch
Old Apr 1, 2005 | 07:34 AM
black99ta's Avatar
So typical. With those drag radials your stock clutch should last you about 4 launches so get the Pro Gold on order right now....
