Bad Slave Cylinder
Based on someones suggestion I pulled the line to the trans and tried again to find the pedal solid, meaning its my Slave that is bad.
I plan on replacing the clutch along with the slave because its probably a stock unit and also I probably dumped 1 pint of fluid in the trans trying to bleed out the system.
I am not using the GM style master, its a Wildwood master mounted under the hood so I don't have any of the odd problems the F-cars do with their masters.
I'm wondering about shims and all of that, assuming a properly working slave, do I even need the shims since the master isn't a problem, good fluid delivery and I'm using a large diameter line going to the trans.
I'm trying to do this on a reasonable price too, what clutch is good for around 440-450 rwhp?
Thanks
Also I have brake fluid dripping from the trans at the bell housing, there is no other leak beyond what is dripping from the bottom of the bellhousing.
My master cylinder is inside the engine bay, it is not integrated onto the pedal, but it is sized for the fluid movement that the GM slave requires.
