and my clutch install saga begins...
Your questions answered, in order:
1. a resurfaced flywheel and the new pressure plate are bolted up and then put onto a centrifuge (a big one) and spun. Much like a tire balancer, the assembly is measured for trueness. The two components are weighed and balanced as one, since they become one component once installed. If the assembly is unbalanced, metal is removed or added as needed to the "low spots", or the centerpoint of the imbalance. Again, like a tire balancer.
2. Yes, it's reasonable to assume the shop did zero balance the flywheel and PP. Then again, assuming makes an "***" out of "u" and "me"...Ask the shop, they should tell you.
3. Technically, no, you can leave the exhaust components in place. But, you'd be better off removing the y-pipe and the hanger for it, for ease of removal of the transmission.
Hope that helped.
Hope that helped.
Originally Posted by Camaro_SS
By "shimming the flywheel" I assume you're referring to placing shims or washers between the flywheel and the crank end? If that's so, then no, not a good idea.
it's not a washer, it's actually attached to the metal. don't know how they attached it, but it's definitely on there, it just looks stock.
you still think it's a bad idea? if it is, why would the machine shop do that?
