Good trans shop in Eastern NC?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hey guys I am looking for a good trans shop to fix my t56 here in eastern North Carolina. I just replaced my clutch with a centerforce, my master/slave cylinder with used ones (could not find any localy new). The car use to grind sometimes when I went into first gear too fast but when the clutch went out it started grinding more often. Finaly when I put the new one in it now grinds most of the time going into first. Only on a rarely does it grind in reverse but that is my fault for not putting the gear in all the way. I dont know how to fix the problem and I am tired of it grinding all the time.
Any help would be appreciated. Thanks.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Must Be In The Air Around Here,im In Fayetteville And The Same Prbolems But Not As Often As It Sounds Like You Do. Im Tryin To Figure Out Who Has What For How Much As Far As Parts Go, If I Hear Of Anybody Really Or Bad I'll Let Ya Know!!!
