Pro 5.0 problems? Or just Problems
Old Apr 14, 2005 | 11:55 PM
FormulaFire's Avatar
Default Pro 5.0 problems? Or just Problems
I put a pro 5.0 in not too long ago. I hear a whistling type noise from 45mph and up. This happened after I messed with the shifter the second time. SHould I be hearing more "car" noises. ALos the shifter sticks between the 1/2 and 3/4 slots. Like the stick will stay all the way over to the left unless I push it over. It doesn't effect my shifting. Just bothersome when I take it out of first and the stick doesn't go to the center. Should this be happening? Should I send it back.. any advice?HELP!!!
thanks,
Justin
Old Apr 15, 2005 | 12:26 AM
JRracing's Avatar
When I pull mine out of 1st it go's to the center, & it used. Just put it on though, so we'll see.
The whistling is probably the rubber boot not sealing up to the tunnel. Take it off & if you have to seal it with some gasket sealer. I bet thats it!!!
Old Apr 15, 2005 | 10:13 AM
ncSSu's Avatar
I read a thread a while ago that talked about the centering springs not being very strong with the pro 5.0, you could search it, I know there are a couple ways to fix it
Old Apr 17, 2005 | 02:46 AM
black00TA's Avatar
yes the pro5.0 is notorious for the weak centering spring. and yes it is notchier than the stock shifter. and the noises your hearing are from the heat/sound boots being removed and not fit into the stock location. when i installed mine it became very loud and i could hear everything from the transmission. a lot noisier than stock but a huge improvement!
Old Apr 17, 2005 | 06:11 PM
Worth it I believe
