Odd RPM problem when in neutral
Old Apr 16, 2005 | 01:57 PM
wantS.O.M.ofthis's Avatar
Default Odd RPM problem when in neutral
If driving between 20mph and 70mph; if I shift into neutral the RPMS will rise or fall to 1700 RPM; but it use to go to the normal 800-900 idle speed if in neutral and if it is at 1700RPM in neutral when I go lesss than 20mph it will drop back down to the normal idle speed. Any thoughts??????
Old Apr 16, 2005 | 02:13 PM
Boosted One's Avatar
It's in the computer tune. If you have edit you can fix it so it doesn't do that by modifing the throttle cracker settings.
Old Apr 16, 2005 | 02:21 PM
Is there a reason it would just start doing that out of the blue? It hasnt always done that.
Guess I will have to get it fixed with the tune after the header install.
Old Apr 17, 2005 | 08:15 AM
you could have a vaccum leak that popped up also.
Frank
