"What Spec number and letter are we up to?"
Old 04-17-2005, 03:24 AM
Sonnymad's Avatar
Question "What Spec number and letter are we up to?"
Hey guy's my Spec 2 just took a dive last month and I've been reading up on a few new models. where in the alphabet soup are we with Spec and what actaully works?
any takers ......
regards sonny
Old 04-17-2005, 06:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Newest Spec 3 is wonderful!
Old 04-17-2005, 08:21 AM
Sonnymad's Avatar
LS6 Block,LS6 Heads ported with larger valves, comp cams 232/232 CAM,918 comp cams valve springs,Lunati 383ci Stroker kit,LS6 Ported oil pump,Rollmaster double row timing chain,comp cams pro magnum lifters,yella terra 1.7 roller rockers,comp cams push rods,dual 3 inch exhaust system with 1 3/4 headers, one stuffed spec clutch,result ??
438rwhp with a stu ffed spec clutch that cant get the power to the ground !
