T56 Oil Temp?
Old Apr 16, 2005 | 08:37 PM
Hunter's Avatar
Default T56 Oil Temp?
How hot does a T56 run? My guage is pegged at 250+ so I jacked the car up felt it and it is so hot that you can't keep your hand on it for a couple of seconds.. Is this right?
Hunter
Old Apr 17, 2005 | 01:41 AM
thesource's Avatar
Drain the fluid and reinstall Royal Purple 01320 ATF . You'll be glad you did .
Old Apr 24, 2005 | 04:32 AM
ls1mojo's Avatar
What about mobil 1 ATF?
Old Apr 25, 2005 | 10:54 AM
Ravenkel's Avatar
TTT, anyone know how hot it is actually suppose to be?, and also which oil to use???
Old Apr 25, 2005 | 01:53 PM
calhoon's Avatar
Don't waste you money on mystry goos use a good quality non-synthetic standard ATF. These transmissions count on air cooling and will reach temps to 300F( start looking at a coolin system at this point)pegging a 250 gage when running hard is not unusual.
