drill mod done, and now...
also, as i bled the system, the clutch came back off the floor. before, when i pushed it down and bled the system, it'd stick to the floor and you'd have to pull it back up. normal?
EDIT: think about it for just a few minutes. You removed a restrition in the hydraulic line. What do you think it would do? Of course it will make it easier to flow so it would feel softer.
also, my friend has an identical clutch to mine, but w/o the drill mod, it's like trying to move a brick compared to mine now! both still grab identical though. you're ok man
As for the brake fluid, did you spill some when you were bleeding/flushing air? that's not tottaly unheard of, ya know
also, the pedal did not stick to the floor when i bled it, although when i bled it before i did the drill mod, it stuck to the floor everytime i released and then tightened the bleeder valve on the slave.
thanks for the help, i think everything is probably (hopefully) okay for now! the clutch isn't as light as an 01/02 clutch, but it's still light in comparison to my 00 clutch.
we bled the clutch 10 times or so, and about the last 4-5 times the stiffness in the pedal did not change, which usually indicates all the air is out of the system.
Jason
and i think the clutch is bled right. i think my gears were always slightly notchy, to be honest. i won't put too much blame on the clutch.
