shifter moves when i get on it
Old Apr 19, 2005 | 05:23 PM
slowscott's Avatar
Question shifter moves when i get on it
when i punch the gas the whole shifter stick torques about an inch towards the passenger side. Do i need a new tranny mount?
Old Apr 19, 2005 | 06:13 PM
98Grnz28's Avatar
You need a tranny mount.
Old Apr 19, 2005 | 06:15 PM
davered00ss's Avatar
Moderator
Yup, you need a new tranny mount. AutoZone has the Energy Suspention ones cheap, but the poly mounts cause vibration.
Old Apr 19, 2005 | 06:34 PM
skippytheloon's Avatar
Some hippies complain about them making noise. I bet your Borla makes enough noise to drown out any "barely audible vibrations" the poly mount may cause.
Old Apr 19, 2005 | 07:45 PM
slowscott's Avatar
thanks for the replies
Is it safe to drive on it for now the way it is? I already have a prothane mount but have not gotten around to putting it in.
Old Apr 19, 2005 | 08:12 PM
Dal1as's Avatar
Um an inch is not that far and your tranni mount may be fine. Does your tranni hit or thud? Get underneath the car and check for rips. If you have the stock motor and tranni mounts 1 inch of movement is not that bad. I mean think of all the people with the y-pipes hitting on brand new cars with new header/catback setups. That pipe is moving about an inch.
I'd check for rips but you probably don't need to change the tranni mount.
Old Apr 19, 2005 | 09:07 PM
8-Pack's Avatar
I drove from GA to CA w/ a broken mount (not by choice) in my 95 Z28 and I never had any problems w/ the car that could have been caused by the broken mount. But since you already have a new one I would get it on quick, its a real easy install.
Old Apr 19, 2005 | 09:59 PM
ddnspider's Avatar
just went through that.blacktransam told me to go to autozone and pickup the poly 1.took all of 20 minutes to install.the car actually feels like it has more bite when i shift
Old Apr 20, 2005 | 05:29 PM
jninan2k2's Avatar
I have gone through my fair share of tranny mounts lol real quick fix tho...had one changed in like 5 minutes just to go race some cobra....anything for the races!
Old Apr 20, 2005 | 06:52 PM
ddnspider's Avatar
unbolt 2 bolts on each side of the tranny crossmember,unbolt the bolt through the middle that goes into the mount,take off the bolts on the mount itself,work backwards with new mount.....piece of cake!
