how much do i adjust the master cylinder?
it feels a little bit tougher than my 2000 clutch and take a little work to push in (not bad), but it goes into every gear with pretty good ease. 3rd gear seems to be a little tougher to go into than it was before, but it could just be my mind playing tricks on me.
i have it set to where the pedal is out as far as it can go, but of course the master can still be adjusted out more. i just don't know how far to take it, but i do want the clutch to engage/disengage properly so as to avoid wear on the thing. thanks for your help.
oh, and it's a spec 2 with a stock flywheel resurfaced.
don't know if this helps, but when i put the car in first and let off of the clutch (no gas) and when i'm at a standstill, i can get the clutch about 2 inches off of the floor until the car starts pulling.
