Damn Skip Shift
Old Apr 25, 2005 | 12:54 PM
Schwindj's Avatar
Default Damn Skip Shift
I am getting fed up with this stupid skip shift nonsense on my 2002 Z28 with the T56. Is there any way to eliminate this at a reasonable price?
Old Apr 25, 2005 | 01:03 PM
B&B01BlkSS's Avatar
http://www.slponline.com/browse_list.asp
Skip Shift eliminator $30.00 from slp
Old Apr 25, 2005 | 01:06 PM
Vertigo's Avatar
LOL, hellya! forget that damn slp thing for $30!!! Here's whatcha need to do...Go to Radioshack and buy a 2.2ohm? .5watt resistor and all you do is unplug the connector and stick the resistor up in the electrical connection and tape it up.!! BTW that resistor at radioshack will cost you a total of $1.50!! Good luck
Old Apr 25, 2005 | 01:10 PM
vettesmakeemwet's Avatar
My T56 is actually in an old vette so I don't have to worry about the engine light going off. But I never connected the skip shift eliminator to anything, and it doesn't work. If you want to be really cheap you can just disconnect the wires from the back of the actuator in the trans. If I remember right, it's not the actuator facing the engine, but the one right next to it on the drivers side. But an engine light will probably go off.
Old Apr 25, 2005 | 01:20 PM
Snapps's Avatar
Talking
Send me a pm with your mailing address and I will send you my skip shift eliminator for free. Via usps. I have no use for it due to ls1 edit
J
Old Apr 25, 2005 | 01:33 PM
MrDude_1's Avatar
i'll try to fill ya in best i can.
the "skip shift" is a little silinoid in the transmission... its in the middle drivers side of the trans screwed in. #1 in the pic attached below.
this little 'noid pops out when the PCM gives it power... when its popped out, you cant shift into 2nd..... as you already know.
now if you unplug it, skip shift never comes on.... but the PCM sees that nothing is connected to it... and pops a SES light.
so what the solution is, is to take a resistor... put it in the wiring half of the plug.
now when the PCM hits the skip shift, it THINKS the 'noid is connected, but really, its only seeing the resistor...
that is all that a skip shift eliminator is... the only diff between this and a commercial one is that the one you buy has a plug on it....
its less then $2 at radio shack for a resistor... just plug it in, wrap it in tape, and zip tie out of the way
Old Apr 25, 2005 | 06:38 PM
Schwindj's Avatar
do i need to drop the trans to take out the solenoid? and what type of resistor do I need?
Old Apr 25, 2005 | 07:02 PM
ArcticZ28's Avatar
No need to drop it, you can see it from under the car. Vertigo suggested the resistor you should get, a 1.2ohm .5-watt resistor. Any radio shack will have this.
Old Apr 25, 2005 | 10:03 PM
BriancWS6's Avatar
Yeah, like the other guys have said about the radio shack deal. It was less than $1 for 5 of them. SOOOOO easy too. I looked at the writeup on installuniversity.com The skip shift light will still come on like always, but no big deal to me. Good luck
Old Apr 25, 2005 | 10:39 PM
clemsonSOM_TA's Avatar
Here is link to skip shift eliminator installation. Gives both kit and resistor installs.
http://www.installuniversity.com/ins...sity/index.htm
Old Apr 25, 2005 | 11:17 PM
BackinBlack02SS's Avatar
Has anyone completely removed the skip shift solenoid, #1 in the pic above, all together and just plugged the hole? Any negative effects to this at all?
Old Apr 25, 2005 | 11:23 PM
ArcticZ28's Avatar
That would def. throw a code, plus you'd have to worry about plugging the hole. The resistor is the easiest way to get rid of the skip shift.
Old Apr 25, 2005 | 11:30 PM
I think you misunderstood what I was getting at. OK, let say I put the resistor in, or even spend the money on a skip shift eliminator, to get rid of the SES light. Now you still have a solenoid in the transmission that serves no purpose at all. I don't like that. I was simply asking if anyone has removed the solenoid all together. Any drawbacks?
Old Apr 26, 2005 | 06:12 AM
calhoon's Avatar
No drawbacks at all. The problem will be to find a plug for the hole. There are plastic ones made( not suitable) but I know of none on the market that will provide a reliable seal. ( Yes I have removed these and I have made plugs)
Old Apr 26, 2005 | 09:48 AM
Vertigo's Avatar
Hey guys sorry I was wrong about the specs on the resistor its actually a 2.2K Ohm 1/2 watt resistor.
I'm going to edit my previous post so nobody gets confused. 2.2 is the right one! Just follow the directions from installuniversity.com ... This mod will take you all of 5mins~!! Well worth it.
Old Apr 26, 2005 | 10:44 AM
If you delete CAGS through computer tuning will the skip shift light still come on?
Old Apr 26, 2005 | 12:09 PM
MrDude_1's Avatar
nope.
Old Apr 26, 2005 | 12:16 PM
calhoon's Avatar
If the light bunches your panties, just put a lunk of black tape over it.
Old Apr 26, 2005 | 01:38 PM
soldeir's Avatar
yeah just pull the plug!
Old Jul 27, 2007 | 12:55 PM
mrbowtieguy's Avatar
Default Skip shift purpose?
What is the purpose of the skip shift? Why?
