Fluid???????????
The T56 is stamped with a sticker 'Dexron III ATF only' (see pic below). However this is not necessarily claiming synthetic. Similar to the synthetic motor oil debate, there are pros and cons that factor in to the decision. Usually, the con is price, as synthetic motor oil runs at least double what is required for regular mineral motor oil.
This can add up fast! However, trans fluid need only be replaced once a year (on my super aggressive why the hell not schedule), or even longer inbetween for normal daily driving, and requires four quarts. So, the price difference is negligible. Now, the properties of synthetic fluid allow it to maintain a contant viscosity regardless of temperature. This is a two pronged effect. First, during super cold starts the fluid is not thicker than it needs to be, and requires no time to warm up. Second, during sustained high speed the fluid maintains it viscous nature, and does not break down as carbon based oils tend to do. Therefore, at both ends of the spectrum there's little doubt synthetic fluid is stronger in all areas except price.
In conclusion, the lubrication consistancy of an oil such as Mobil 1 or Redline allows it to maintain a constant thickness regardless of temperature. I haven't even talked about shifting feel which is known to improve as a side effect of running synthetic ATF.
This is a pic of my sticker, sorry I don't have a 90 degree image:
Here is an excellent write of of 4th Gen maintenance projects:
http://www.bfranker.badz28.com/fbody/lubeoil.htm
