Spec Clutches are a SCAM!!!
Well, with only a 120 day warranty, if I was spec I would say break in too. that way when it breaks they can say it's out of warranty.
i drove my clutch under 3000rpms in the city for 430 miles, until one night i hit it from a 20mph roll and went through 3rd gear; did that 2-3 times. drove the car easy another 100 miles or so and then did it again. i plan to continue to drive the car a little easier until the chatter completely dissipates. i also don't powershift or ever do clutch dumps; actually, i rarely drive the car all that hard. if that's not a spec-approved break in, i don't know what is.
all i can say is that the whole reason i got a new clutch was because i thought everytime i shifted the car at WOT before i got the stage II i smelled a weird smell. i assumed it was the clutch, but the smell is still there post-install and i have absolutely no idea what it is. regardless, i spent about $500 trying to figure it out. if this stage II craps out on me, i'll be severly pissed and i will never, ever buy from spec again.
and after reading accounts like these, i'm nearly certain that "proper break in" means absolute ****.
I have around 100 passes on it with 60' in the 1.57-1.65 range.It works far better than the Mcleod I had in my camaro.
02, how many miles does your clutch currently have? like i said, i'm convinced the "break in" has little to do with spec failures.
