stuck in 4th gear
Old May 4, 2005 | 05:02 PM
Georgia99z28's Avatar
Default stuck in 4th gear
for some reason my t-56 keeps getting stuck in 4th gear. I can put it in reverse and my reverse lights will come on but when i try to move it bogs down like its stuck in two gears at once. Last time I had to tear it down and it looked like it was in 4th and 1st at the same time. I thought I had it fixed but it just happened again, about three weeks later. If anyone knows of anything like this happening to some one else, let me know b/c I dont know whats going on.
Old May 5, 2005 | 06:22 AM
calhoon's Avatar
IF it is stuck in 4th and you can select another gear, you have some serious problems. A broken fork/ linkage or severely damaged bearings are most common ways to get two gears at once. I suppose it could be due to mis-assembly as well.
Old May 5, 2005 | 08:57 AM
bitcypher's Avatar
This is a common problem and there's a GM technical note on fixing the issue...
http://www.corvetteactioncenter.com/....php?qstId=533
Old May 8, 2005 | 12:13 AM
02SOMWS6's Avatar
You have a broken slider key. When you have it fixed go with a set of billet slider keys.You can order parts from G-force transmissions
Old May 11, 2005 | 02:32 PM
just wanted you to know you were right. It was the keys. All three were broken. I just got the new ones in today from g-force. just wanted to say thanks.
