**Stock Adjustable Master Cylinder Writeup**
#41
emfuser did it fix yours? my trans is brand new AND SUCKS, it was built by SSI and i KNOW its got to be right, but i had a TO of problems after my swap to a t56 from the start lol
#42
I can't believe I never noticed this. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I had a LS7 clutch/LS2 flywheel combination installed with new clutch hydraulics and a SSI rebuild on my T56. I've been wondering for ages why that ****** is so notchy, and this has GOT to be it.
Am I just pulling the MC right off the hydraulic line and doing all this on a bench? I'm leery about getting air in my system just by doing this.
You are going to get in the system, you are opening it up...Just bleed it when finished
#43
Just did mine but my dum *** used a 3/8 X 24 die, oh well it will allow for very minor adjustments now
off to ace to get the right coupling nuts. Thanks for the bad *** write up.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#45
There ought to be a note regarding putting the MC back together that says something along the lines of this:
To reassemble the master cylinder you're going to need a friend, preferably a linebacker, to hold the assembly together while you spend 3 hours fat-fingering attempts at getting the ring to actually go in-between the cylinder and the plastic retainer piece. We send our regards as you end up sending the pieces flying all over the place in vain enough times to ruin whatever you're wearing, as well as your surroundings.
#46
Is it really necessary to cut the bump stop? I thought it was to stop the piston before the spring got to coil-bind. Also, on an unmodified car isn't the master cylinder stroke limited by the clutch pedal hitting the firewall, not the internal bump stop? It would save people a lot of pain if disassembling the master wasn't necessary.
Edit: I ended up doing this finally and the disassembly/reassembly isn't all that bad. It's a good opportunity for a fluid flush anyway.
#47
#49
In an unmodified car it may be true that the pedal stops at the firewall. If however, the master is made adjustable, wouldn't that move the low end of the plunger closer to the bump stop when the pedal is on the floor? I too thought it might not be needed. I did it anyway though and it wasn't too bad.
#50
Hey Chuck. So you cut the stop or did not? I wonder how much travel past the firewall there is before you hit the stop.
I see you got the trans worked out finally. So should see some solid numbers this season. What clutch did you go with?
#54
Just did mine and it took about 12 minutes from take apart to back together. I had my son (16) hold it in place while I used a samll screwdriver (kind for electronics, watches and stuff). Just get the bottom of the ring in first and follow it around kinda backwards putting pressure on it. It was real fast. Hope this helps.
#58
I finally got around to doing this today. It wasn't as hard as I thought it was gonna be with the reassembly. I was considering not opening up the internals but I'm glad I did because I found a bunch of sludge in the master cylinder.
I was going to try to replace the retaining ring with an internal snap ring from the hardware store. 7/8" is too small and 1" is too big, just barely though. The retaining ring wasn't that bad once I got someone to hold everything together while I fed the ring in.
#59
I just encountered a problem on my adjustable master I made. The rod that gets threaded back towards the master itself broke in half. It broke towards the bottom where I ran out of threads. It looks as if there is an empty space inside for a quarter inch or less and with the threads there made it real weak as it is just hollow. Just a heads up for people. I have an extra rod that I can use but I will not be threading it down nearly as far as it is instructed here. I don't want to go clutchless that far away from home again.
#60
OK... this is incredibly easy and made a dell of a difference.
I used a small pick and started the seal back in without a problem.
I did it all according to the above directions. But i wouldn't have gut off .5" if I did it again I would probably try and just cut it and thread.
