t56
Old May 8, 2005 | 07:49 PM
peterock98's Avatar
Default t56
I my transmision needs a rebuilt.I don't have a lift .What's the best way to do it on the floor.
Old May 8, 2005 | 09:03 PM
tippmann243's Avatar
i would put the car on 4 jackstands
Old May 8, 2005 | 11:16 PM
01SLPSS's Avatar
Mine has been on four jackstands for about 3 weeks now, It Sucks!!!
Old May 9, 2005 | 03:14 PM
ssmark165's Avatar
Get a good helper.
Old May 9, 2005 | 04:07 PM
peterock98's Avatar
I took off the shifter,driveshaft and the y pipe so far.Hopefully I'll finish it tonight.
Old May 10, 2005 | 07:15 AM
peterock98's Avatar
I got it out last night.What a pain to get that top bolt on the passenger side.
Old May 10, 2005 | 08:47 AM
1madss's Avatar
There is a little metal tab that holds the vent tube in place on that bolt. I do not use that tab anymore, it is a giant PITA to get back on and makes taking the bolt out more difficult.
Old May 10, 2005 | 03:42 PM
peterock98's Avatar
I should have it back in a couple of days.
Old May 12, 2005 | 12:53 PM
peterock98's Avatar
ttt up.I need a little help.The trannys is back and I'am not sure about how to reconnect the slave .Do it just put back in or do I open the bleeder then put it in.
Old May 12, 2005 | 01:24 PM
Steve Burger's Avatar
LS1TECH Sponsor
Either way. Try with the bleeder closed first. If it won't go then crack the bleeder to relieve pressure.
Old May 12, 2005 | 01:32 PM
peterock98's Avatar
Will it introduce air into the system.
Old May 12, 2005 | 02:41 PM
LS1TECH Sponsor
Either way will require a bleed.
Old May 13, 2005 | 07:45 AM
peterock98's Avatar
What path does the ss braided line take behind the heat shield?Does the rubber covering go between those 2 mounts or does the line say on the side(left or right)
