clutch question?
if you are wondering about clutch wear, and if you have to manually compinsate for that wear in order to keep clamping pressure, then no...
what you do have to do is change your hydrolic clutch fluid and insure you fill it to the "fill line" as over time it will go down(a very little bit) with wear...
for more info see the clutch post in my sig...
in stock form, you should look at the very reasonable spec clutches...
several sponcers sell them...
if you drive pretty hard... and have got 30-50k on the odomiter, there is a good chance yours is on its way out....
no better time to upgrade
