Possible worn clutch?
Old May 10, 2005 | 11:44 PM
JD_AMG's Avatar
Default Possible worn clutch?
Just got the car, it has 38,000 miles on it and a stock clutch. The grab of the clutch is about an inch away from the end of the peddle, is this "normal"? The clutch doesnt slip at all, it seems to grab fine, its just that it grabs much farther up than any other manual car Ive driven.
Old May 11, 2005 | 12:14 AM
Krab's Avatar
I don't really understand if the clutch engages an inch off the floor, or an inch away from barely pushing in the pedal. If it engages real close to the floor, then you might just need to flush out the old fluid with new fluid, then bleed the system for any air. A mityvac helps a whole lot when doing this.
Old May 11, 2005 | 01:12 AM
soldeir's Avatar
if it is holding fine than the disk is in good shape try what krab said about the fluid
Old May 11, 2005 | 08:37 AM
JD_AMG's Avatar
Sorry for the bad way of explaining it. Its about an inch away from barley pushing in the peddle.
Old May 11, 2005 | 11:06 AM
Krab's Avatar
Seems normal to me. My stocker used to engage at about the same point and so does my spec 3 with updated hydraulics.
Old May 11, 2005 | 01:02 PM
JD_AMG's Avatar
Alright, thanks a lot. (ive never driven a manual f-body before this one, so I didnt know whats "normal")
