Help with transmission
Old May 12, 2005 | 02:01 AM
SLP4CamaroSS's Avatar
Default Help with transmission
ok i got a 2000 camaro ss (71000 stock clutch) still when i drive around normal it shifts fine and smooth but when i get on it sometimes the clutch pedel sometime goes to the floor a little and soemtiems it doesnt. Also when i get on it i noticed a couple times i can shift 1st and 2nd just fine but when i try to put it in 3rd it doesnt let me or any other gear i have to wiggle the stick back and forth and and then it will let me in any gear. Is it my slave cylinder or shift forks or what.
Old May 12, 2005 | 11:32 AM
vettetech's Avatar
sounds like you have 2 problems. i would install a new master and slave cylinders,as well as new shift fork and 3-4 syncro.
Old May 12, 2005 | 11:46 AM
i might as well get a new clutch, slave, and rebuilt tranny waht all tranny parts do i need for a rebuild
Old May 12, 2005 | 04:57 PM
black00TA's Avatar
check out D&D they have a nice selection of aftermarket parts for the T56. most importantly. shift forks and synchros.
