Used stock flywheel ok with spec?
Yeah any time you replace a clutch, the flywheel should be resurfaced or replaced. Also, the stock flywheel and presure plate are balanced together as a unit from GM, so if you just throw another presure plate and clutch on there, it won't be balanced as well as before. You should get the flywheel and presure plate zero balanced before installation.
