Powergrip HD Install ??????????need help
Old May 17, 2005 | 07:47 PM
nutz'00 Z28's Avatar
Default Powergrip HD Install ??????????need help
I am installing the ram 98931hd, in my 2000 Z28 using the stock flywheel.
I had it resurfaced and started putting it all back together and ran into a problem on the flywheel there are 2 dowel-like pins and the ram pressure plates doesnt have the holes for them to slide into?????
NEED HELP
Old May 17, 2005 | 08:31 PM
glennster's Avatar
Pull out the dowels and throw them away.the bolts will center the plate.I hate to tell you that the HD set will probably eat the stock flywheel also.
