Mcleod masters still having problems..?
I am amazed that mcleod can't seem to fix this problem on these expensive
things and for sure will never buy a mcleod product ever again.
I willl also be ripping out that master if the rebuilt don't fix it and going with a texatralia or mabye clutchmasters clutch.
Anyone else still having bad luck with their mcleod masters lately.??
Oh it worked good when first installed although it was hard to bleed and used a mityvac and then no gears and you could pump it like two hundred times and get them again sort of but let it sit and back to no gears again.Sure it has to be master .The clutch was working fine ,cartech clutch with the modified factory master but that master would not hold its setting.
I have no luck with masters it seems..
