Just bought a Ram
Old May 17, 2005 | 11:40 PM
Firebirdguy00's Avatar
Default Just bought a Ram
I just bought my new clutch,the Ram Powergrip,and the Adj. Master. Im new to 6 speed and this adj master im not sure about. Can anyone give me advice on any of this?
Old May 19, 2005 | 06:31 PM
mike c.'s Avatar
advice...yeah. i've had two rams(910 and 980) first lasted 1,100mi and 2nd lasted 2,200 mi. i hope you have better luck then i did. just so you know......i also had the ram flywheel,new adj master and slave installed with my rams. goodluck,i hope you have no problems.
Old May 19, 2005 | 10:41 PM
991LE's Avatar
The hardest part is getting all the air out of the system. Buschman's Clutch Bleed Method might help give you some ideas on how to make sure there is no air in the system.
