Spec II or III?
Old 05-20-2005, 06:25 PM
camarodave98's Avatar
Default Spec II or III?
I currently have around 380-400 hp, but will be getting to the 500-550hp range very soon. Which clutch is for me? I have been told the spec stage 3 is hard to daily drive with. Is the II the same thing?
David
Old 05-21-2005, 05:29 AM
Demon_Speeding's Avatar
I'd say go with the SPEC 3. From what I've read and what's been recommended to me the SPEC 2 might be OK for what you've got right now, but once you make that jump in power the clutch probably won't hold.
Old 05-21-2005, 12:04 PM
slow14U's Avatar
I've had 3 spec III's and only one worked. I put down 527/605 to the wheels at the time. The clutches eaither work or they flat out don't. I would'nt mess with a spec II if you are going to be puttin down 500-550 like you said. Spec III's drive like a stock clutch accept a little chatter. My girlfriend, who knows nothing about cars, didn't know the difference between the stock clutch and the spec III. If you go spec III, you must, I repeat, MUST break it in for at least 500 miles. If you don't, you WILL be replacing it.
Old 05-21-2005, 12:14 PM
mattslightning's Avatar
personally i would not get a spec i just installed mine a month ago stage 2 nice 750 break in period the car has a HORRIBLE rotational vibration i am going to remove it this week and throw that piece of JUNK do yourself a favor buy a name brand clutch don't waste you time and money like i did
