Shifter moves durring acceleration..
Old May 26, 2005 | 12:29 AM
00Z28 Camaro's Avatar
Default Shifter moves durring acceleration..
My whole shifter " shifts usually to the Right-> when I hit the gas , do I need new mounts or somthing ?
87,000 miles btw
Old May 26, 2005 | 12:33 AM
LS1TORQ's Avatar
Mine does too, I've got 106k. I dont know if this is good or bad. I also notice if i shut off the engine with the trans out of gear I hear a loud knock, knock, knock. I dont think its the y-pipe, maby its the trans. It doesn't do it if its in gear though.
Old May 26, 2005 | 10:51 AM
I dont have that knock, I guess its just motormounts or somthing
Old May 26, 2005 | 01:32 PM
LS1TORQ's Avatar
well I am thinking that knock maybe a trans mount and thats why the shifter moves to the right. I don't know.......my motor mounts look good but I have never looked around while someone shuts the motor off to really pinpoint the problem. I'm thinking the shifter moving to the right might be normal....thats just a guess
Old May 26, 2005 | 01:43 PM
BrandonSS's Avatar
Drive any M6... new goat will do the same thing. Maybe not as severe since it has new mounts. But all move. If you get a banging or clunk then the mount needs to be replaced.
Old May 26, 2005 | 02:03 PM
Oh , False alarm I guess
Old May 26, 2005 | 02:05 PM
Steve Burger's Avatar
LS1TECH Sponsor
Mine does not move at all. I do have poly motor and trans mounts though.
Old May 26, 2005 | 03:35 PM
gotzaGTO's Avatar
its normal, its the engine toruqing when you rev, check out the trans mount and engine mount, if in tact, dont worry about it.
Old May 26, 2005 | 03:40 PM
Tranzor's Avatar
Yep, it's normal when you have a stock rubber mount. I have a poly trans mount and poly motor mounts and mine doesn't move at all under acceleration.
Old May 26, 2005 | 04:06 PM
How much does a poly trans mount go for ?
Old May 26, 2005 | 04:12 PM
Tranzor's Avatar
You can buy one from one of the sponsors... they range from $20-$25 or so. I bought my Prothane mount from Thunder Racing.
Old May 26, 2005 | 09:45 PM
gotzaGTO's Avatar
They need to make one for the MOTHER F**KING GTO!!!!!!!!!
Old May 27, 2005 | 03:03 AM
LS1TORQ's Avatar
I figured this was all normal but not my knocking problem. How hard is it to replace motor and trans mounts with polyurethane. What advantages does the polyurethane bushings give??
