help with textralia install
update, I talked to Pete and he recommended doing a different slave bleed method. Pump the pedal about 10x, then leave it out, unscrew the bleeder, quickly push the pedal down and hold it, then tighten the bleeder. I did this method about 4 times, and then re-mityvac'd the MC reservor (only got a few very small bubbles).
I cant notice any big difference in the pedal but I tried starting it up and I was able to get it into gear with just a little bit of grinding. (definitely not like before).
I tried putting it in first and push the clutch in and apply brakes and it still stalls the engine.
-Now, the clinking sound comes and goes (it sounds possibly like something is binding maybe). If I pump the pedal a few times, put it in first, I may not hear it (with clutch in or out)
-If the tranny is in neutral it dosent make the sound, only in a gear.
-If I put it in first and it starts making the sound, if I push the clutch pedal it still will make it.
-Once it didnt make the sound when I had it in first with the clutch in, then after about 30 sec. it started making the noise (with cluch pedal pressed still)
You said it doesn't make the sound when the trans is in neutral, which means the driveshaft, rearend and wheels are not spinning...correct?
