help with textralia install
The clutch pedal is pretty stiff. Its kind of easy at very top, then hits a stiff part, and that resistance goes down to the floor.
I put the car in gear and started it, and then pushed the clutch in all the way then applied the brakes. The clutch did not slip, the engine just started to die.
Is it possible something else is worng or do I just need to keep bleeding the slave more?
Is there a way to check to see if the slave is moving correctly?
I was wondering about the spacer/shim thing but I dont think the textralia setup is made to use one; so I figured it's some other problem, either air or some problem with the slave functioning
https://ls1tech.com/forums/manual-transmission/327094-textrailia-clutch-install-questoion.html
How would the clutch be dragging, is there some way to check this?
I used the intall tool, then positioned the PP over it and put the bolts in, then I jiggled the intall tool/disk to re center it and then turned the bolts so the PP was almost flush with the FW (the PP being under tension) then torqued the bolts in the 3 stage sequence.
The disk should be so that the springs/raised center part is facing the transmission, like this right?
The slave should be assembled and bolted to the tranny, and then just raise/slide the tranny shaft into the clutch splines, right?
They cover that in here, sounds similar to you problem.\
http://installuniversity.com/install...ch_install.htm
The car is on jackstands btw, not on the ground.
I guess I need a shim, but Ill have to talk to textralia about it
By dragging we mean that it is not fully disengaging, that the Clutch disk is actually still dragging across the flywheel surface. This is what is happening with mine....but yours sounds like you have ALOT of air in yours still. This is why you cannot put it into gear while the engine is running. I thought mine was manufacturing air somehow
Since we are on the subject and Ive tried just about everything else, What is everyone using to reverse bleed? and by that I mean what are yall actually using AT THE BLEADER??? is it a piece of tubing going over the outer part of the bleeder, or is it a special tip from the mity-vac kit that you are fitting inside the bleeder hole???
After you get the air out of your OZ clutch, you won't regret your choice. I LOVE mine. I just have a little (and i do mean little) bit of air that i still havnt managed to get out yet. Peter and Jeff are great guys, If it would make you feel better send Peter a PM or call him, It's an 800 number (pm me if you need it...just remember that they are in a completly different time zone from us, so call in the afternoon.) so it will not cost you anything to call. I really liked doing business with them btw, they want the clutch to work just as much as you or I would.
I was going to try to hook the mityvac up to the bleeder with a 90' elbow and the little needle fitting, but I was worried about air entering the bleeder when the vacuum is removed and you try to screw it in.
If you unscrew the bleeder with the pedal out, the system should "gravity" bleed right? so it I used a vac on the bleeder (to assist) I could wait untill the vac goes away, then slowly push the pedal as I tighten the bleeder... sound good?
This probably still wont be as effective as having a lot of vacuum to suck the bubbles out, how would you "pressure" vacuum bleed with the bleeder like the reservor? without letting air back in the bleeder
keep me posted on what you are trying/ how it worked
