problems lauching the spec stage 3
now with the new clutch last night tried to lauch the same blew the tires apart took the revs down to about 3800-3900 slipped the clutch longer on video the car moved about 2-3 feet and then lit the tires up.....last pass rolled out of the hole at like 3500 and the car bogged
for those of u running the spec stage 3 clutch what is the best way to lauch on this clutch or what would u guys recomend....on the stock clutch the car went 11.63@120.3 w/ a 1.75 60'
anyway wed night the first pass the clutch spun up right off the line........after 1st gear just coasted and let it cool down for about and hour......2nd pass it slipped hard at about 5000rpm.....every gear.....let it cool down again this time for about 30min made 3 back to back passes the first pass bogged on purpose to see if it would grab enough to pull out of the bog.....it did the 2nd pass it spun up a little bit in 4th......on the last pass everything seemed to be fine...
is this something they all go through as the break into to track use or whats the deal here......im ready to throw the stock clutch back in......atleast with that i can cut 1.7's
