how much can stock t56 gears handle
i'm going to get some gears from liberty, i heard that they use stock gears though. will stock gears with liberty's treatment handle 800-1000 rwhp, or will i need to go ahead and get the g-force and have liberty do them?
At that level You're Pushing it with the treated Liberty gears... I say go with it.. Unless the G-Force gears are not much more expensive.. Just make damn sure you take care of that tranny!! No major Power Shifting, unless you want to break it.. When you shift make sure it's in the gear your going into before you really get on it.. Make sure your Hydrolics are all up to snuff.. Clutch Strong and able to handle the power. I would not go with an aluminum flywheel. Go with something stronger like the SLP Billet or equivelent..
Good luck..
Clint
Good luck..
Clint
i've heard people say that the spec stage 5 clutch will handle the power in a proshifted trans. isn't using the clutch defeating the purpose in a proshifted transmission? i have the z06 hydrolics right now, what else is there on the market?
