A4 to MN6...How To Wire Clutch Neutral Safety Switch
Hey,
Almost done my A4 to MN6 Swap in my 2000 Vette. Put in the clutch pedal assembly. There are 2 sensors on it...One towards the firewall for the clutch neutral safety switch so the car only turns on when the clutch is fully engaged. And I presume the other is for cruise control which I dont care about.
How am I supposed to wire the clutch neutral safety switch? From what to what? Any other wiring I will need to do?
Also for the CAGs...do I need to do anything special for that? Does that need to have a wire run to it as well? Or just install the CAGs defeat and i'm done.
Thanks!!!
Thanks!!!
