Yet another Spec 3 Install...
I didnt have the PP and flywheel balanced at all because no one in the Des Moines area does that. I dont have any balance problems and the car seems to be smoother after the install. I had the stock FW resurfaced (took off .015").
I hardly have any chatter....just a tiny bit if I let the clutch out too fast. Shifting got smoother as the revs stay up between shifts...dunno why though
TIPS:
-Drain tranny before removing
-Use your right hand (palm facing tranny) to put in the torque arm bolt mount..took me 2 minutes.
-Fill the tranny through the shifter hole instead of that little 'fill' hole. Stock 6-spd takes 4 qts of Dexron III. Mine took 3.5 qts after reinstalling.
-If you have access to a hoist/tranny jack, use it (My neighbor has one in his backyard pole building
) Yes, you always take the tranny off of the bellhousing first, then remove the bellhousing afterwards...if you dont do it this way, you will end up fighting it a whole lot when you go to reinstall it. You still will need some long extensions to get the top bolts of the tranny. I had two 24" extensions and it was plenty.
