One Hose On My Slave Cylinder
Why do you think there should be two? It's a closed system.
Fluid travels both ways in that line. You push the pedal and the fluid is forced into the slave cylinder. When you let off, the slave cylinder releases and the fluid is sucked/pushed back up the line.
