Now what!!!??? 2nd to 3rd prob.
Let me know. thanks.
I know i've heard of the drill mod (somehow fluid's not returning fast enough to disengage the clutch?) but I don't know exactly what it is....
But I believe it's more than that!! If he can shift at 5500 rpms but not at 6500 rpms then the problem is more like the pressure plate is not fulley disengageing.. He might need a spacer plate behind the slave cylinder.. as well..
Good luck..
In the upper Extreme RPMS your Pressure plate is not disengaging enough to shift properly. I'll bet you developed some hot spots as well on the pressure plate and flywheel.. You need to get the pressure plate to Fulley dis-engage. To do that you need to get the slave cylinder closer to to the pressure plate fingers with that spacer, or the adjustable Master Cylinder..
If it was in my hands I would drop the Tranny and see whats going on.. I'll bet your Carbon Or Kevlar pads are little flared out, perhaps and causing the problem of not disengageing. A Slave cylinder can only travel so far, so the option of dropping the trans and spacer on the slave is what I reccomend..
Good luck.
Clint
