Sound lk a shifter or tranny problem to you?
Ive had the Pro 5.0 shifter installed for about 2 or 3 years now, and i remember it feeling pretty sweet when i put it in.
Now that is def. not the case at all. When the car is in gear it is very sloppy. Its in gear, but i can still move it around. Ive checked every bolt to the entire shifter and everything is tight. I would make a guess that it is the tranny. What in the tranny could cause that? I mean the shifter is so loose and sloppy it can pop itself out of gear. Also while in gear, 4 out of 6 gears, without my foot on the clutch i can easily pull it out of gear and into neutral. Its gotta be the tranny. What in the tranny is going bad or is already bad?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by calhoon
The socket that the shifter fits in may be worn. The trans will not wallow like you describe while in gear. You have a worn socket or shifter.
